lapping plate
blackkarma
MoN-sTaR
Jan 17, 2007
335
jacksonville, nc
so i heard through the grape vine that someone here loans/rents out lapping plates. i cant seem to find a local shop that even knows what a lapping plate is if someone could help me out i would greatly appreciate it.
Try a machinery supply shop, they're a common tool.
Not keen on the little round plates as they're easily overpowered by "muscle" and can leaves a less than flat surface, the plate I use is 12"x12" with centre mounted handles you use to guide it, as always Lapping is ONLY a finishing process used to smooth a true/flat surface left by the milling machine.
CT26smoker
223
Houston
I found a nice one in the industrial section of eBay.
6x13 inches, cost me $35 + shipping.
There is a lot of good deals up there on industrial equipment.
blackkarma
MoN-sTaR
Jan 17, 2007
335
jacksonville, nc
Yeah that's what I thought....but everyone here in Nola looks at me like I'm retarded when I say the words lapping and plate in the same sentence. How much did that 12x12 plate cost you? I was only looking for a 8x8
suprarich
Guest
Nov 9, 2005
2,187
ohio
IJ - Did you cut grooves in your plate or leave it flat? I had grooves at a 30 degree angle on one side and flat on the other side.
suprarich
Guest
Nov 9, 2005
2,187
ohio
That sounds like it would cut very well IJ
For those reading the this, a lapping plate with grooves in it will cut more aggressive that a flat plate. Generally you would use the grooved side to start, and a the flat side for the final finish. Not that our MHG's need more that just the grooved side.
I've been using it with Diamond paste and it's quick/easy/economical, I haven't rolled the diamond paste onto it though I think even with a fine grade it would be far too aggresive so just dab some around the deck with some veggie oil (canola) and go to town.
