knocking problem?
spawntaker
1jz lover
Nov 15, 2008
150
Conroe,Tx
well here it is. i have a knocking noise coming from my turbo supra. i have not drove the supra with low oil and dont know if the previous guy did or not (highly doubt it). i have rev it high a few times and read that if a engine is rev'd high it could bend a valve. also heard a bent valve can make a knocking noise too. but if worst comes to worst which is cheaper to fix a rod knock or a bent valve? and what test can i do to figure out which one i have with out taking the engine out and apart? im trying to sell the supra but need to figure out which one i have rod knock or bent valve. can a compression test tell me if i have a bent valve? if i drain the oil is there any way of tellling if i have rod knock (like peaces of shards in the oil)? i have not drained the oil yet but will do later. and lastly if i ran the engine just for a bit to get a video of the knocking will it hurt it any more?
Aug 12, 2010
347
P.G. County, Maryland
Rod knock sounds like someone is beating on your block with a ball peen hammer. Valve tap sounds like someone typing really fast on an old keyboard. In almost all cases, valve tap is easier and cheaper to fix, because depending on how bad the knock is you could need to have your block bored for new bearings, you may need a new crank (more than likely) you'll need new bearings, and you have to disassemble and clean your entire motor to keep the tiny shards of bearing from destroying everything. Did you read the stickies at the top of this section? I'm pretty sure there is a gigantic thread about rod knock, not to mention three new people create a OMGIHAVERODKNOCKOHNOES!!! thread every day...
---------- Post added at 12:22 PM ---------- Previous post was at 12:15 PM ----------
Apologies, it was in the Engine Internals/ Mech section. Who would have thought? http://www.supramania.com/forums/showthread.php?20486-Rod-Knock-Diagnosis-and-FAQ
Also, HCRAES!!!
http://www.supramania.com/forums/sh...-is-a-knock-knock-knockin&highlight=rod+knock
http://www.supramania.com/forums/showthread.php?18206-knock-knock-knocking-on...&highlight=rod+knock
http://www.supramania.com/forums/sh...innaly-went-to-rod-knock.&highlight=rod+knock
http://www.supramania.com/forums/sh...od-knock-if-its-a-DIY-job&highlight=rod+knock
http://www.supramania.com/forums/sh...know-you-have-a-Rod-Knock&highlight=rod+knock
Get it?
