Knock sensor locations
shaeff
Kurt is FTMFW x2!!!!
9
Around
The GE had one, about dead center in the block under the intake manifold. I'd post up links w/ pics for you, but cygnusx1 is blocked by my job.
ronnie4
136
Huntsville
If it's the sensor I am thinking of then the electrical connector is broken off, anyone know if one from a MKII will work? Is the oil pressure sensor the one on the exhaust sude near the front of the block?
HitmansEVO
Dropper
Nov 19, 2008
Missouri
suprahero;1222409 said:
On the GTE they're on the drivers side under the intake manifold screwed into the block. I don't know for a fact, but I was thinking the GE only had one, but maybe it has two like the gte. Have you checked in the TSRM?
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
The GE has one. There are three nubs or whatever you want to call them on the block. The GE block has the middle one threaded, and the GTE block has the outer two threaded. I'd post pics.. but i'm at work. There are pics of it on the site somewhere.. most of them get blocked for me, though.
ronnie4
136
Huntsville
So the first picture is the knock sensor and second picture the oil pressure sensor? Anyone know if a knock sensor from a 5m will work?
