Is the jzz30 sump the same as the jza70?
And if it isnt is it able to be ued and clear the jza70 crossmember?
Thanks
Logan
Thanks
Logan
itr.00-1282 said:The supra is mid sump. what is this rear sump that I often hear people talk about? Did the JZ engines come with 3 different sump configurations??
The only ones I have seen is front and mid (rear?). And I personally yanked my 1JZ from a Soarer clip and dropped it in my Supra. The pans are the same between the two.
Hopefully someone can clear this up because I have never seen a JZ oil pan with the sump located all the way in the back.
