Jzz30 ma70
Knomio_JDM
4
Tennessee
Ok guys, I am having a problem with my soarer jzz30 swap into a 1986.5 Supra. I have no power at all. When I drive it down the road it won't go above 45mph. When I do wide open throttle the RPMs don't climb. All cylinders are firing and all intake tubes are hooked up. I have a hx35w turbo on there and I only have it putting out factory boost right now. I'm using a 1996 Toyota Camry MAF sensor. Could this be the cause?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
could be a lot of things - make sure the part #'s are the same from the camry to the supra.. ive had my timing slip once causing this...
jzz30 is non vvti. should have a map sensor.
and a map sensor off a camry would not work.
