Like everybody said don't do it.
When you weld the spider gears, you are basically making one solid bar from wheel to wheel. Both wheels turn at the same rate at all times. Your differential is gone, as is your ability to go around corners smoothly.
With a normal differential, when you go around corners, one tire has to turn faster than the other, in order to keep things moving smoothly. When you weld the rear, the tires can't turn at different rates. This puts a lot of stress on drive train components, and at some point in the turn, something has to give. Usually it’s the tire to pavement contact, as you know this will wear down your tires fast, some times it's driveshafts or drivelines or some various part.
So simply put welding the rear end is a bad idea unless you only travel in a straight line or like to go mud bogging. It will cause extremely premature death of driveline components as well as making driving a pain in the ass on even the smallest of corners.
