JUN 272 high lift cam shaftsdoes
does anyone have the spec sheet for these camshafts. i have tried searching on here and google, and cant find all the details i am after. or if someone can provide a link with the details i am after. the JUN website dosnt list the information i am after either. and also does the 2jz head need to be modified to accept a 10.8mm lift cam shaft, i cant find a definitive answer to that either.
JUN 272 HIGH LIFT CAMSHAFT (ALL INFO CONFIRMED BY JUN CONSULTANT)
ADVERTISED DURATION: 272 DEGREES
DURATION @ .050":??
LIFT: 10.8MM
LOBE SEPERATION: 110 DEGREE
BUCKETS: SHIMLESS REQUIRED
RETAINERS: EITHER JUN RETAINERS OR MACHINE BOTTOM OF STOCK ONES TO CLEAR VALVE STEM SEAL AT FULL LIFT.
MACHINE TO CLEAR LOBE ROTATION: ??
TAPPET CLEARANCE: INTAKE O.2MM EXHAUST 0.3MM
