If you are prepping for a MHG, you'll have the block torn down. (You need to in order to deck the head surface)
Since you're having that done, get them to magnaflux the block, hone the cylinders and line bore the mains at the very least. You should also have them polish the crank and re-size the big ends for your rods.
At that point, they'll tell you what you need in terms of head gasket thickness and bearings for both rods and mains. New piston rings would also be called for. None of these things are a big extra cost at this point.
