I did a JDM 2jz-GTE swap in a MK111 N/A. It has been nothing but problems. The most recent is when started the engine will rev fine for about 8 seconds then will sputter and die if the throttle is pushed. It will continue to idle though. Any thoughts?
There are no mods of any kind. Have installed new coils, igniter, have 2 ecus they both do the same thing, new Map sensor. All the vacuum lines have been replaced. new fuel pump.
