ISC on NA-T
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
Just curious, when you do the NA-T conversion, do you use the turbo ISC valve with that little round oneway valve, or do you just use the stock NA ISC valve?
I'm trying to figure out if I can run without that oneway valve on my turbo car with a custom intake manifold.
jdub
Feb 10, 2006
10,730
Valley of the Sun
You need the check valve to prevent a boost leak through the ISCV. The ISCVs are the same for both...the check valve in is a recessed area below it.
