That's the lower IC pipe in direct contact with the thing below it.
E Eriol New Member Mar 31, 2005 308 0 0 Indianapolis May 26, 2008 #1 That's the lower IC pipe in direct contact with the thing below it.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under May 26, 2008 #2 Not normal.
E Eriol New Member Mar 31, 2005 308 0 0 Indianapolis May 26, 2008 #3 IJ.;1033747 said: Not normal. Click to expand... Is it very far off normal, or just a little? The front end has been smacked a couple of times (by previous owners), and I think things are a little out of whack.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under May 26, 2008 #4 Can the damper bracket on the rack be rotated? (86.5 here no damper so I'm not sure)
E Eriol New Member Mar 31, 2005 308 0 0 Indianapolis May 26, 2008 #5 I don't think so... it looks like it's an integral part of the rack.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 61 I come from a land down under May 26, 2008 #6 Can you bend the bracket that holds the IC pipe in place?
Poodles I play with fire Jul 22, 2006 16,757 0 0 42 Fort Worth, TX May 26, 2008 #7 That's the aluminum elbow, it should be bolted into place. If it's not, get it bolted back in.
E Eriol New Member Mar 31, 2005 308 0 0 Indianapolis May 26, 2008 #8 IJ.;1033779 said: Can you bend the bracket that holds the IC pipe in place? Click to expand... Not on that axis, I'd have to drill a hole in the bracket. I was thinking about having Jon (MDC) fab up some hardpipes for me, though, so I guess now he'll have to have the car while he's doing it.
E Eriol New Member Mar 31, 2005 308 0 0 Indianapolis May 26, 2008 #9 Poodles;1033786 said: That's the aluminum elbow, it should be bolted into place. If it's not, get it bolted back in. Click to expand... Yep, it's bolted. I'm guessing my rack is too far up, or the elbow and bracket have been pushed rearward somehow.
