Is there a replacement tie rod end dust boot?
suprabee
Celicasupra.com Member
May 18, 2006
112
Scotts Valley, California
I have a tie rod end dust boot that is cut. I want to replace just the dust boot. The joint is still good. I've replaced the boots on my MKII with an Energy Suspension boot for ~ $5 for 2 boots. It seems there are no aftermarket replacement dust boots for the MKIII. The ES dust boot for the MKII won't fit on the MKIII tie rod.
Is there one that you know of that will fit?
I've searched, and find it odd that this has not been brought up before, but perhaps that means there is no replacement options, and the solution is too just replace the entire tie rod.
thanks
Rick
mkiii222
Troy, MI
Rock Auto has them listed as Rack and Pinion Bellow. Plenty of choices but closer to $10 per side than $5 for both.
Sent from my SM-G935V using Tapatalk
suprabee
May 18, 2006
112
No not the rack and pinion bellow. thought I was specific enough with the "end" part of my description, but I'm looking for the OUTER tie rod end. The rack and pinion bellow is for the inner tie rod.
