Ok guys, I own a 1992 supra, 1jzgte, It has a AEM ems, Masterpower T70, MKIV 550cc injectors, Well the car made 422hp at the wheels last year around march, Well the motor took a dump (rodknock) I got another one & went single, I bought all the fuel goodies from Aaron at driftmotion, Walbro 255lph fuel pump, 1jz fuel pressure regulator kit, Fuel damper braided line, Well i got everything installed, The car got finished this past august, It started right away, I drove the car for 2 blocks, Let the car seat since august, Now, Chicago has been having really fuking cold weather, I charged the battery & started the car in this weather, The car started right away!! I was very amazed, I heard AEM suck at start-up in cold weather, Well the car was low in gas, I when to Autozone to buy a 5 gallon gas container, Filled it up, Went home pour it in, Car started right up again, Let it run for 30 minutes to atleast charge the battery, I did this for about week, I left the car running & went inside the house to take a quick bite, I go outside & the car is not running, I crank & i cranked it but the car won't run, I pop my hood & see the gauge for the AFPR & it's at zero!!! For a moment i thought to my self................Did i run outta gas??? So there i go to BP amoco & got me some good ole 93 oct....Got home pour the 5 gallons in & go to crank it....
Same shit!!! just turns But doesn't run! AFPR is at Zero! I used to hear the walbro before & i could hear the fuel flow to the regulator, Now is my fuel pump dead or is the AEM not giving power to the fuel pump??? How do i check for power to the fuel pump?
Please help, I am very pissed at the car at the moment.
