My car has been having this problem off and on lately. For the past couple of weeks, it will randomly start misfiring. It sounds like a lawnmower, and the engine has absolutely no power. It sounds like it's misfiring on 1 cylinder, but it could be 2. Here's the thing, though: when this happens, I'll drive it down the road for a little while and then it will suddenly stop misfiring and will start behaving normally again. Today, it did this several times as I was on a long trip, until it started misfiring one last time, wouldn't stop, and I had to limp it home.
I checked for codes, and came up with code 14 and a code 43. 14 relates to the ignition coil/igniter, and 43 relates to the ignition switch circuit. However, I cleared the system, and now it's not throwing any codes. I'm thinking of replacing the ignition coil, but I'm not entirely sure. I just replaced the spark plugs, distributor cap, and rotor. My wires are nearly brand new. All of the wires were sparking at the distributor cap, but I didn't check at the plugs themselves.
Thoughts? :dunno:
Thoughts? :dunno:
