Ok this might be a little long but need to type the whole history. I’m at the point of parting it out and need any thoughts or insights on the situation.
Ok, bought my supra with the engine already pulled because of rod knock. Took the engine apart and to the machine it went did everything they recommended for it. In the mean time my stock-ish rebuild kept snowballing into a full on build (check my build threads if you wish). So motor got put back together and dropped in. Drove it to get the exhaust made up had like a ¼ downpipe for it. Got home from that and started noticing some noises couldn’t identify it. We thought it was the head yada yada. So eventually out came the motor and flipped it over and the main bearings were scored up pretty good with some damage on the rod bearings (this was all with the same rods and etc from the original engine).
Well since I had already went T66 FFIM etc etc decided screw it should’ve done forged anyways so lets just go forged. So bought a brand new set of Crower Rods, Titan Main Caps, Wiseco pistons. Went to a Machine shop in Orlando recommended by Titan. Took everything there and explained what we wanted etc. So he assembled the rods/pistons balanced everything bored the cylinders, cut the crank so on and so forth. He couldn’t do the align bore of the billet mains so went to a respected shop in Tampa for that.
Got it all back and put back together with ARP hardware everywhere. Mains torque set to 80lbs and Crowers torque set to 45lbs with a brand new torque wrench. Got it all installed started it up and at about 30-45seconds hear a ticking noise but had very good oil pressure and throttle response.
We thought for sure it was the valve lash measured it and it was all messed up. We fixed the lash and still had the ticking noise. We then had some people listen to it everyone was like oh that’s forged noise. I didn’t believe them and knew something wasn’t right. Pulled the motor again took rod cap #1 off and it looked like this :
……with a small piece of metal welded onto the crank
#6 rod had some damage
and the others had some early wear, all the mains looked to be good. So I was extremely pissed at this point and then we found out about the Crank plugs that we didn’t know about needing to be cleaned.
So figured that was the problem. Took it all back to the machine shop and explained what happened and gave them the entire rotating assembly with a fresh stock un-molested crank. Asked them to cut it 10/10 check the main bore, the cylinder bore to clearance the bearings balance the new crank replace and clean the plugs etc. Got it all back put back together and same freaking identical thing instant noise at about 30-45seconds. Haven’t taken it apart yet to see the bearings.
Someone was being a smart ass and was like the rods are backwards which triggered a thought process and after extensive research and looking at all my pics we’ve determined that the machine shop did in fact assemble the rods backwards. The notches for the bearings were on the exhaust side not the intake side like they should be.
So that being said would that cause instant knock/noise like we are getting. If not what else could be causing some of these issues. I can’t keep spending money on a wild goose hunt/trial and error.
Cliff’s:
2 instant rod knock engines after assembly of forged internals, Machine shop assembled the rods/pistons backwards and we didn’t realize/think to check it. Could this cause an instant knock.
Any other ideas on what would cause instant rod knock.
Before you start saying I don’t know what I’m doing I’ve had people who have built a lot of these motors over pretty much doing majority of the work and all torque spec’s followed to the “T”.
Any help/thoughts would be greatly appreciated!
Cliff’s:
