So my car has been running rough for a while and i decided to dig into it today. It sounds like bad timing mixed with a bad misfire. I replaced all the plugs recently to try to fix the problem but it had no effect. I checked the TDC and all the plug wires and found that with the plug wire to the 6th cylinder removed it actually ran better... It ran like it was perfectly in time with a single misfire. It seems like Cyl 6 is firing but it is hitting at the wrong time and bogging out the rest of the motor like its only the 6th cylinder thats out of time.
Any ideas?
Ive heard:
Check Compression
Check injector
Any other ideas? Anyone else had this problem? Any help would be greatly appreciated.
Any ideas?
Ive heard:
Check Compression
Check injector
