injector swap?
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
I tried to search for this but was spending hours going through things that had nothing to do with it. can you take a jdm 440cc injector from a 2jz and put it in a 1jz's fuel rail? or can you put the 2jz fuel rail and injectors on a 1jz? I was looking for a mild injector upgrade from the stock 370's. I'm currently only running stock twins anc realise they do hit fuelcut around 16lbs but if I upgrade to gt12s I'll be able to run more then that.
