injector o-ring set price
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
Hey guys.. how much does the injector o-ring set go for at toyota. i got a quote from toyota and it seems a little steep?? here the email i got from them
Hi Kevin
a) o-ring at top 90301-07001 @ 4.80 each ( you require 6 )
b) grommet at top 90480-13005 @ 5.60 each ( you require 6)
c) insulator at bottom 23291-41010 @ 5.70 each ( you require 6 )
all would have to ordered
Steve
all that totals to $96.60 BEFORE taxes...
supra_man87
EL GUAPO
Nov 15, 2007
241
So. Col.
If you send the injectors, dont they usually replace the o-rings in the process? I heard rc did it, dunno if they still do.
iwannadie
981
gilbert, az
PureDrifter;1558301 said:
i picked up everything i needed from my local napa warehouse for like $2-3 for ALL the seals for each injector, total was under $20.
Same here, I even ended up with 2 extra sets because they were so cheap I figured why not incase I lost/damaged something.
That seems way too high even from toyota for o rings. Ive bought them new from toyota once but i dont think it was more than 20 bucks.
