Infamous Code 51
smagnotta
SuprSal
WashPa
Hey all,
I read the threads concerning code 51 (thanks jetjock for the nice write-up). My car's RPMs stay high even at operating temperature. My S-AFC Neo also has throttle hovering between 1.0% and 1.2% instead of 0% with the throttle closed.
I am going to try to adjust the TPS using my car's TSRM or replace it with another one.
If that does not work is there anything else I could try? I do have another throttle body I could use.
smagnotta
SuprSal
WashPa
I adjusted the TPS and it now reads 0% as it should with the idle closed. The only thing is there is a dead spot in the throttle where the idle fluctuates. I am still getting code 51. I am going to try another throttle body and a brand new TPS. This is annoying.
marlonvip
Supra -only way to fly
Sep 2, 2006
189
Denmark
Hi there,
I had the same problem......I bought a tb with and tps sensor which havnt been removed or adjusted and that fixed it right up:)
good luck
Marlon
