Ignition will NOT turn engine over
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
Recently purchased a a 87 a/t 7mge
Im having some issues with the starting system
basicly
I have a hot battery
headlights come on
no check engine lights ect... come on
I havent tried to jump the starter over to see if I can get the engine to spin yet ,Im looking for futher answers to this issue ,before I replace things that dont need to be replaced
Thanks for any help .
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
CRE;1106720 said:
Check for error codes, then, if there are none I have two questions. Does the starter make any noise when you turn the key? Have you set off or removed the stock alarm system?
Error Codes:
http://www.cygnusx1.net/Supra/TechTips/engine_error_codes.aspx
Thanks for the info:
no noise from the starter.
Its been raining where i live so I havent had the time to check yet But will asap.
I havent set off,or removed the alarm system, But I bought this car with this issue ,so maybe the previous owner set off the alarm .
I dont think the alarm has been removed though
Thanks again for the help.
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
dr chill;1106858 said:
thanks for the info:
No noise from the starter.
Its been raining where i live so i havent had the time to check yet but will asap.
I havent set off,or removed the alarm system, but i bought this car with this issue ,so maybe the previous owner set off the alarm .
thanks again for the help.
ok the rain died down some ,so i have had a better look at the car
here are a few of the other issues
1, no power to ignition
2, no power windows
3, no windshield wipers
4, no dash/gauge lights,or gauge activity when the key is on the on position
5, no door lights when the doors are open
6, no beeping sound when key is in the ignition
any ideas
thanks everyone !!!!!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Lol.... uh, let's go with the shorter list... is there anything that's actually getting power?
Get the battery tested and test the fusible link in the engine bay fuse box (on older models it just looks like a burnt chunk of wire... it's supposed to look like a thick, insulated wire).
If the fusible link needs replaced, do NOT replace it with regular wire.
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
Ya, Ive replaced that wire on all my other supras
its an easy task
I'll let ta know what happens.
also gonna replace the starter & ground wires / check for corrosion or bad connection
Thanks for the in put
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
Issue has been resolved
it was the fuseable link ..Looped.. wire in the fuse block under the hood
most likely never been replaced in 2O years
Thanks
:biglaugh:
