Ignition - No dash lights, No Crank, No sound!
bryan767
Maryland
the ignition in my 1jz swapped sc300 stopped working the other day:
key in ignition, turn to acc - nothing, turn to start - nothing. there are no clicking sounds from the relay, no cranking or anything. i checked the fuses and they look fine. any other ideas? all of my lights work, the steering wheel position still moves, and the battery is under 5 months old.
i was looking at this:
http://www.lextreme.com/dx-starter.html
and saw the Anti-Deterrent ECU thing.. it sounded like that was my problem but it didnt work.
symptoms
-No Acc power
-no dash lights
-no radio/climate
-headlights/steering wheel tilt work
-no clicking relays
-no sounds at all
IGNITION CONTROL SWITCH?
vmoua509
SpokaneSupras
Sep 17, 2007
Spokane, WA
check your ground wires! Had the same symptons in my buddies 88 supra turbo. After we finished replacing the clutch and putting everything back together, it wouldnt start! I checked the ground wires from the the negative battery post and all of the other ones around the engine and underneath the car, and moved some around and tighten them all up.......... it fired right up!
