ignition making noise
2jzgte
Arima
hey guys having a little problem i have a 2jzgte in a is300 lexus but i am getting a ignition noise when the boost coming in...........the brain is stock...
the car is tranny............but the car is boosting and i'm getting 20psi which should not happen any ideas.....what is going guys.....thanks in advance the help will be great............or its de jdm engine...........
MINA
162
sacramento
so your boosting 20 psi & u dont know why, that noise your hearing might be detonation i could be wrong tho. 20psi stock fuel and management>?
2jzgte
Arima
yeah its completely stock..............the boost gauge dats wat it showing 20psi.........ok guys wat u tink i should do boost controller. to limit it..wat u guys tink. de noise is like when a chain rackelling noise.....is it some thing very dangerous............
2jzgte
Arima
so wat u think i could do.................mina tanks change it. wat check i go do to see if de waste gate is bad
ians13
537
Jacksonville, fl
i also have a is300 powered by 2jzgte, now about your problem if you have a 3" exhaust from the turbo back it will over boost past 20psi, this will kill you engine in time. if you do have the twin turbo setup you need a restrictor ring or a 2.5" down pipe, or a catalytic converter. what am saying is you need some back pressure to help the small stock wastegate, i have a 2.75" down pipe with a 2.5 " exhaust the car is quite and it boost no more than 11.5psi
spooln30
milwaukee,WI
Man your typing skills need vast improvement. " the car is tranny" LOL.
Boy oh boy I missed this "so wat u think i could do.................mina tanks change it. wat check i go do to see if de waste gate is bad"
People don't mind helping other guys out but if you don't make sense and babble on like this then your open for shit talking. Just saying.
