Idle vacuum pressure
smagnotta
SuprSal
WashPa
Just wondering what my boost controller should have as a vacuum value when the car is idling? It looks like around 16.5 (a little past the 16 hash mark). Is this normal? Why I am asking is the car idles a bit rough (misses).
Thanks,
Sal
mkIIIman089
Ohio
Thats on the low side of normal IIRC. It might be more accurate to get a mechanical vacuum guage thats more accurate to check for sipping or spiking... that will tell you if there is a problem with many things. http://cygnusx1.net/supra/techtips.html go to the vacuum reading thing and it talks all about this.
smagnotta
SuprSal
WashPa
Thanks for the link. From what I saw it could be late ignition timing. Looks like the one thing I didn't check could be it...
supra_dre
not sure if i'm on the right subject, but my Profec B II reads around -80 (-8) psi at idle.
smagnotta
SuprSal
WashPa
I thought I should be around 20. Oh well at least it is steady at 16.5 and does not fluctuate. Looks like I need to see if the valve timing and ignition timing are OK. The car has 121,000 miles and the timing belt was changed by the previous owner at 75,000 miles. Maybe I will replace that too since I am in there checking the timing...
I have taken this car apart so many times... :p
Idealsupra
Orlando
www.tampabaysupras.com
16 isnt that bad...do you ever look at it after you drive for a bit? mine is usually around 15-17 until it warms up and then it idles around 20-22...
timing could cause a low vacuum but 16 isnt that bad really...
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
what, knowing that metric vaccum readings arent important???
no one else mentioned that average vaccum is 500mm/hg. i figured thats useful information for those of us running a Metric boost guage... like anyone w/ a Defi, HKS or GReddy... you know.
I don't think he knew you were being serious, he probably thought you were trying to be funny or something...
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
lol. cmon guys, i always try to be funny!
i typically dont postwhore to post whore... i make ita point to say something constructive even if the main basis of my reply is off-topic... like when i make fun of Jayson for being jewish or something like that.
but anyways, 500mm/hg is about average for good vaccuum. alot of times, it can fluctuate either way by 50mm/hg depending on idle speed, isc steppery or timing.
