IAC valve
Deeznuts
80
VA
Can I use the 2JZGTE IAC valve on the 1JZGTE. And does it matter if the 2JZ is turbo or not?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
My simple IAC fix for those who want to know:
If it's stuck open, remove the tube going to it, and insert a cork (it fits perfectly into the rubber hose). Drill a hole in the cork and file it out to gain appropriate idle speed.
Deeznuts
80
VA
I can actually remove the big black round thing from the housing on the IAC valve for the 1JZ. Maybe I can make a 2JZ one fit in the 1JZ IAC houseing.
tissimo
Stock is boring :(
Melbourne, FL
IIRC the 2jz is not removable. I THINK the 7ms is though.
tissimo
Stock is boring :(
Melbourne, FL
lppro;1149068 said:
i know because i dont have mine connected right now... cold starts are a bitch.. it wont idle until i keep it running for like 5 min.
pull a vac line.
I did that with my old honda beater I had, IAC went out, sealed off the IAC and just pulled a vacuum line off. Idled ~ 500 cold and 700 warm. It didn't have a/c so wasn't a huge deal (would of rigged some ghetto VSV for idle up if it had it).
tissimo;1149083 said:
pull a vac line.
and suck unfiltered dirty air into the engine....
