iac ran to the atmosphere on factory ecu
Supraguy7M
7m forever!
Jan 9, 2013
198
bennington vermont
So I got thinking, (got a new job so I haven't had much time to work on the ol girl), I have my iac ran into a breather pulling fresh air from the atmosphere. Seeing as its un metered air, when I am still running the lex afm setup, would that cause my poor idle, and make it run rough? Just trying to pick your brains. Idk where else to look.
Supraguy7M
7m forever!
Jan 9, 2013
198
bennington vermont
I thought so, but I figured I'd check with you guys. Thanks jetjock an novadude. I've been fighting a timing issue that probably wasn't timing.. :/ all cuz I couldn't get it to idle.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
You bet. The 7M TCCS is an outgrowth of the Bosch L-Jetronic system. Toyota calls it L Type EFI. L is for "luft", the German word for air. Means the system measures airflow rather than manifold pressure and for things to work right all of it must be accounted for.
7M4EVR
695
fah, fah away
^...what the hell you are like in person... some sort of cross between Abraham Lincoln, Isaac Newton, and Bill Hicks or something?
