Skip down to the cliff notes if you don't feel like reading all of this =\
Ok, so I recently dropped in a JDM 7M-GTE with a new MHG/ARP studs into my 89 N/A, figured out the wiring, got it running, etc. I've just registered it and have been driving it for a week, and some minor issues have come up (clutch master cylinder, A/C compressor locking up, a few boost leaks, etc) but now I hear a very, very faint noise when the engine is idling that sounds like rodknock. I thought I heard knocking earlier on, but it was so very faint and nobody else could hear it, so I decided I was just paranoid from reading so many RK stories on Supramania. Unfortunately now it's loud enough that I definately know it is there, though most people still can't figure out what I'm going crazy over.
I've done some research and definately can say it is not a loose crank pulley, valve train noise is separate from this sound, no coolant ever got into the oil when changing the HG (though some may have gotten in when the engine was being used in japan?), and I have isolated all the random noises I could find, like exhaust hitting the transmission mount and a loose A/C belt tensioner pulley that actually flew off the car. It's a manual so the A/T thingamajig can't be making the knocking noise.
But I am confused. Because I can only hear the knock at idle and sometimes when I blip the throttle lightly up to about 2000 RPM. It gets faster with RPMs but not louder, it actually gets somewhat quieter. Even stranger, I cannot hear it over around 1500 RPM when driving with the engine under load. There is a chance my exhaust noise is covering it up since it's so faint, but even with the exhaust silencer in I cannot hear the knock.
The noise is easier to hear when my head is under the car than above. I do have a slight exhaust manifold leak because one of the studs somehow came loose and is spinning freely, but I am relatively sure that is not making the noise.
Is there anything else that could cause a knocking sound that I have missed? I'm not going to drive the car anymore until I figure out what is wrong. It's quite depressing, I've never had any experience diagnosing rod knock and am already addicted to the Supra enough that I will go through withdrawal if I have to pull the engine and fix rod knock =( I'll try and borrow a video camera and take a video, I tried to do it with my phone but the sound quality is horrible. Looking at videos of rod knock on youtube, it is a similar noise but much more pronounced and a LOT louder on most videos. I suppose it could just be that everyone's video was recorded when their knock was already really bad... does RK start out really faintly?
I'm hoping someone will pop in and suggests something I never thought about that fixes the noise =\ I suppose I should have opened up the bottom end of the engine when I got it, if even just to check it. Tomorrow I will try disconnecting injector clips one at a time to see if I can locate which cylinder the knock is coming from if it's from a rod. Unfortunately my oil pressure guage never worked and my efforts to rig up wiring for it and 2 other ones have been unsuccessful, so I don't know if it's just low oil pressure or something.
Sorry this is so long, I'm sort of half thinking out loud and typing it down I guess.
Cliff notes:
I hear a slight knocking sound at idle, a bit more so when the engine is warm than when the engine is cold.
It is easier to hear when I am near the bottom of the engine than standing over it
The sound can be heard when I blip the throttle lightly to about 2k RPM, while the engine is decelerating (no load on engine, free revving)
When I drive it and there is a load on the engine, I cannot hear the knock after about 1500 RPM...
Thanks to anyone who takes the time to read this and add their comments.
Edit: UPDATE!
I went and listened around with a screwdriver. =( I must be doing it wrong because everything on the engine just has a static noise to it, like a TV when it's on a channel with no reception, but quieter. The only things that make noise are the injector clips when I touch the screwdriver to it and listen, and those seem to be tapping twice as fast as the knocking noise.
Also, pulling the injector clips... it just makes a new knocking noise at a different rate that is a lot louder. I dunno, I only pulled the #5 clip because it sort of scared me when the engine did that. Is that what is supposed to happen?
Another really weird thing, when I first started it up, it idled at around 500 rpm and I couldn't hear the knock. At all. Then I pushed the gas a little bit after a good 2 minute of idling and head-scratching, and when it settled down again the idle was at about 650 rpm and the knocking was there. WTF mate?
Cliff notes:
Edit: UPDATE!
