I need help with the rear subframe and rods
chesky911
19
avila
Hi,i have a problem with the rear subframe or rods,my supra has bad stability on rear wheels when it "caught a culvert,pocket...
I replaced a rear left camber rod and rear left axle carrier,replaced rear sway bar and also replaced old shocks and put new coilovers but the problem still exist.
I think that the rear subframe broke "cushion"or "bushings".The car has a violent lateral balance on rear with "caught a culvert,pocket...
Si alguien sabe español también se lo agradecería
Sorry,i speak english a little
Thanks!
SC61 MK3
316
FL
Drop the subframe and inspect. Not too hard, I just did it.
First remove exhaust and disconnect 4 14mm driveshaft bolts from differential.
Disconnect 2 10mm bolts on e-brake cables and disconnect
Than pull out rear struts/springs, loosen brake caliper bolt and support caliper leaving brake line connected.
Use a jack to support center off diff and remove the 2 14mm and 3 19mm on each side of the subframe
Slowly lower jack
Here is a walk through, a little different http://www.mk3supra.org/topic/109-guide-removing-a-rear-subframe/
chesky911
19
avila
Thanks!!!,next week I'm going to change the complete rear subframe,I'm going to use my other supra to pieces.
I wish that problem finishes
