i need an opinion and some info on a vintage camshaft needing some rework
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
ok guys i am in the middle of procuring parts for my vintage datsun racecar engine. i have found a fairly rare race camshaft grind that has some minor pitting on the upsweep side of the lobe. i can get it extremely cheep due to this. it is an overhead cam engine and has a 9000rpm redline. can i have this repaired? what are the risks of running it as is?
here is the damage
also who could repair it
benchwarmer;1641912 said:
Don't run it as is or it will chew up your rocker. Have it reground as mentioned above and re-shim as necessary.
If it's an L series engine it will have cemented carbide pads on the rocker (same stuff they make Lathe cutting tips out of) so I can't see it chewing the rocker....
If you were Ultra paranoid you could have it hard face welded then reground to spec but if it were mine I woulkdn't bother and just run it as is seeing that's it's suce a small percentage of the surface area then inspect it from time to time.
fixitman04
Sep 18, 2008
787
north dakota
it is a u-series engine, and it will come with the later style hardened rockers. it is a bre cam, very little use, then shelved for 40 years
fixitman04
Sep 18, 2008
787
north dakota
so you would run it? i can get this cam for $50, it is priceless in my opinion though due to its former owner. so aside from it going flat or destroying the rocker there is no real risk?
It won't even mark the rocker (Don't know about the U engines but if you screw the geometry on an L the rocker will slice the lobe clean off without leaving a scratch on the rocker they're that hard)
My way of looking at it is it's only "worth" something if it's rare AND mint, this cam isn't and never will be so I'd run it and inspect it from time to time, as I said it's very minor pitting, not really sure how it would have happened other than it may have been a slightly porous blank to start with way back.
fixitman04
Sep 18, 2008
787
north dakota
well the damage occurred during storage. he said the cam had torn box, and paper. it had a little spot of rust there, he cleaned it off while getting ready to send it to me and found the pitting. im tempted to send this cam to a cam grinder to be copied... this grind was never released to the public. it was a bre insider only item. the grind is worth more than the cam. i would have to talk to the bre guys to get permission though.
im gonna buy it then, and enjoy it thoroughly. this is a perfect example of why you should always properly store parts. one mistake and damage occurs.
---------- Post added at 03:31 PM ---------- Previous post was at 03:30 PM ----------
the later u series engine uses the same design of rocker as the l series.
