I made a 1988 engine harness with gray plugs
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
I have finished something that took some time, but was worth it. I took 91 harness plugs and cut them away from the harness. So I had the plugs from the 91 harness and I cut my 88 plugs off and replaced them with the gray plugs. Here are the pictures from the evolution.
By the way, this harness works great and I have had no problems with it. I plan on running the Mine's ecu I have with this harness.
Whasian
shaeff
Kurt is FTMFW x2!!!!
9
Around
I would have de-pinned the harness clips rather than cutting/ soldering/ heat shrinking it all...
JesseH
1,153
Englewood, Ohio, United States
looks good, never seen anyone attempt that one before, but im with shaeff, i wouldn't want that many spliced wires, it would take longer to de-pin them but you wouldnt have to worry about one of the connections coming loose
bryanintexas
aaarrrrrggghhhh!!!!!
Apr 4, 2005
605
spring, texas
I was wondering if anyone had done that. Very interesting.:naughty:
Agreed.
Are there the same number of PIN's yellow/grey plugs (less the HAC)? Are the PIN's the same style? Anyone know.....?
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
The pins on the +89 are different than the pins on the 88. Rather than trying to find the right pins and everything, it was easier for me to solder and heatshrink the wires.
Whasian
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
The soldering portion wasn't so bad. it was time consuming, but I went slow and went wire by wire. I have no worries about the connection coming apart or loose.
Whasian
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
Are there the same number of PIN's yellow/grey plugs (less the HAC)? Are the PIN's the same style? Anyone know.....?[/QUOTE]
There are is about a 4 or 5 pin difference in the yellow plugs verses the grey plugs.
Whasian
