I did a Gs300 this time :)
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
So after getting out of Supras for a few different reasons, mostly boredom lol, I decided to buy a 1st Gen GS300 and stick a 2jzgte in it. Apart from buying the motorset, everything else was pretty much leftovers or things I wanted to do to the Supra but never did.
Here goes : I'll just cut and paste from club Lexus :
The car :
Now I am moving on to the GS300:
The car:
The Engine Replacement:
The Turbo replacement : These are home made KKK26 turbos from the Porsche 944. :biglaugh: and are welded onto the stock 2jzgte manifold.
Two tial 38 mm wastegate and routed back into individual downpipes running off the turbos.
Valve covers stripped :
Turbo cleaned and painted :
Valve covers : Painting in progress
Super simple wiring harness work. All it needs is to be extended about 20 inches wirte for wire. No pinning needed. A lot easier than MKIII swaps.
suprastanger507mgte
Hayward , Ca
Drilled and tapped the Manifold for the brake cylinder vacum.
Engine is removed with the help of some friends - Look at the somewhat dirty bay :
TRANNY COOLER :
Engine bay cleaned with Simple green, scrubbed and waxed :) Looks ten times better now :
Stuff getting replaced :
MKIV TT 6 speed aluminum radiator...
For the TRANNY :
98 SUpra MKIV Mounts :
IC and piping set :
Tranny cleaned, washed and painted :
Turboes :
Turbo Headers wrapped in Heat wrap :
suprastanger507mgte
Hayward , Ca
The engine installed .
Anyways..here are some engine pictures :
HYDROFAN mounted. Used the hydrofan and shroud setup from a 84 Camry v6.made some custom brackets, though.
The turbo outlet piping actually fits and was designed to clear the ABS lines . And it sits in perfect location to run the IC piping down.
Enjoy :
suprastanger507mgte
Hayward , Ca
Here is some foto from my phone with IC mounted. Will be routing the IC piping today :)
Here is a quick startup video...its loud without the exhaust but the engine sounds very good.
Here is a short video I took. My friend stopped by and game a hand..( in the video ) lol
Car as it sits. I was going to put a fiull body kit, but will only use the front and buy a different sides/and rear maybe.
Here is a couple of phone photos I took of the car with the body kit parts I put on.
its in the body shop now and is getting a fresh coat of 202 Black .
rear tail :
Front :
Car is now at the body shop getting a frsh coat of Toyota 202 Black. That was its factory color.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
I always loved 1st gen GS's..
my mom has a 94 in pearl white/gray...
the front is alright, open up the headlights and remove the orange insert like they did on my mom's car..:-D
Suprapowaz!(2)
2,870
San Antonio, Tx.
I'm not one for body kits so I won't comment on that. So what was it that you heard that made you get in closer to listen to? I'm assuming your bought that neato turbine welded to the exhaust manifold set up dirt cheap, and couldn't pass it up. What was it previously on? What kind of power did it make? Was it worth it?
suprastanger507mgte
Hayward , Ca
Mk3runner;1377981 said:
interesting build.
why did you weld the turbos tho? couldnt find a flange to fit??
When I wanted to put this on the Supra, I searched a lot for the flanges and could not find them around.
When I did find some, the guys wanted $150 a piece..so I said f*&'em and never did it.
I had a chance to buy this manifold setup ( yes welded ) and it has held up quite well for the guy. This is a DD kind of car and not something that will be entered into shows or pushing any real high horsepower and such that.
it fits the bill for a "project car on a budget" :biglaugh:
Mk3runner
2,033
Nor Cal
eh, good stuff! not knocking it, just dont usually see it. when are the cruise vids and some boost vids coming up?
suprastanger507mgte
Hayward , Ca
Thanks guys :
I just put the car for a full paint job ( same 202 black) and it should be ready by end of this week. I just delivered the paint today.
Cruise and boost videos will be up in a few weeks after everything is sorted out. My twin HKS silent power exhaust is on the way too. I will need to fab up a twin into one 3 inch (less than a foot long) pipe to connect the dp to the cat back.
MDC - the turboes are temporary. Once I have enough saved up for good fuel setup and a good turbo setup, they will be coming off in favor of better manifolds/fuel setup.
Here is where I got the setup ideas from : 13 psi waste gate springs only
Automatic gs300 running the same turbo setup.
http://www.youtube.com/watch?v=aqTnNcNjQSU
seen the dyno sheets - around 354whp/343torque @ ~12 psi. But I will validate this myself..
suprastanger507mgte
Hayward , Ca
Mk3runner;1385994 said:
any updates?
thanks guys. It definitely has a nice feel.
Updates ??
Yes, the car is now painted all black like factory . Had a free hookup so I just got it done. Not the best job but free is free. At least the rock chips and the front aftermarket bumper is painted as well as the rear trunk spoiler.
Also had the guy paint my Intercooler for a stealth look.
I need to wait for the paint to cure for at least a few weeks before I get the car buffed.
I am still in need to find a muffler shop who will make me a y-pipe without complaining or turning me away because there are no cats involved.
Here is the exhasut that I have waiting to put on :) Dual HKS Hi power.
