i cant indentify these noises.. maybe you can?
88YotaTurbo
658
Wolcott, Ct.
I would say it's from some pulley. Try taking off the accessory belts and checking each pulley for wiggle/play. Don't just buy a new pump without making sure that is the problem.
sounds like a rack going out or not enough fluid
also the screens in the reservoir get clogged take a screwdriver and cut a hole
but the pump pulley also could be the problem
kaz87supra
Supra Owner
Owasso OK
have you checked your power steering fluid level? really sounds like it is just low. probably caused by a leaking pressure hose or worn rack.
mine runs out almost daily and i will get lazy so it might be a week before I refill it, and I am just waiting for the pump to die from no fluid, but it still keeps on ticking and sounds new when I fill er up. basically, im saying you probably havnt damaged the pump if all that has happened was you ran it low on fluid.
Adam
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Checking the suction screen is a good idea. Punching holes in it, thereby sending all that crap into your hydraulic system and defeating the screen for future use, is not. Makes me wonder what the poster who suggested it does when he gets something in his eye...
Start by checking the fluid level. If low and adding doesn't help remove the reservoir and flush it with solvent until the screen is clean. Might as well replace the fluid in the entire system while you're at it. Fill it all back up and turn the wheel lock to lock until there's no more air in the fluid. Ignore any noises while doing it. If you're smart you'll add a filter in the return line. Google "magnefine". You want the inline gadget.
If needed the pump can be replaced or rebuilt with a kit from the dealer. Not hard to do. If the rack is shot you'll need to replace it. Also replace the high pressure line if it's old. Try the screen clean and maybe a fluid flush first though. Course, all this assumes the PS is indeed your problem.
it's the PS system, wouldn't make more noise when turning the wheel...
It uses ATF, not PS fluid as well, can't count how many times I've seen someone destroy their pump using PS fluid...
johnathan1
Supra =
Aug 19, 2005
5,056
He punches a hole in it of course! LMAO
I did that to my NA Supra back when I was still a fresh n00b...:cry:
well thats what one of the older techs in my shop told they used to do for that
and if the fluid was never changed and theres that much dirt in the system already how would it hurt?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Ummm....how about just taking the Resv off and cleaning the screen?
Dirt kills hydraulic pumps ;)
ya i under stand what your saying about the proper way.
but if the entire system is dirty from never changing the oil the screen is just going to get clogged up right away again.
the power steering fluid is usually neglected to be changed by most vehicle owners and a lot of the supra owners on here are not the first owners and who noes if the fluid has ever been changed.
no, cause the dirt was stopped by the screen, so it's NOT in the entire system, or it would already be on the screen...
It's not like it's hard to clean either, syphon the fluid out, unbolt the res. and undo the two hoses. Flush it with degreaser in the reverse of the flow (in through the lower bung).
Then, do a flush of the system (not hard, the TSRM shows EXACTLY how to do it)
