I can’t adjust the A/F at idle to keep it at 14.X to 15.X, I adjust the mainscale and the lowtune with out luck.
What can I do?
Source File: PTR210 Test 03 July 24 '08.bin
Source Definition: TPro4800.xdf
Airflow Source 0x00 Select
Barometer Comp Mode 00
Freq In Mode 11
Aux 1 mode 01
Main Scale 30.00
Volts Out 1 Setpoint 2.45
Volts Out 2 Setpoint 3.53
Afterstart enrichment 5.00
Tune Load Point, Low 36.40
Tune Load Point, Mid 100.10
Tune Load Point, High 143.00
FE Smoothing 30
AFR Min TPS 3.00
AFR Min RPM 3200
AFR Min Load 150.89
AFR correction lean limit 11.60
AFR correction rich limit 10.00
AFR correction gain 4.00
TPS Enrichment 0.48
TPS Decay 0.80
Throttle Body Size 8
TPS MAP Max 104.06
MAP Enrichment 0.40
Boost Enrichment 0.40
MAP TPS Min 0.44 Volts
MAP RPM Min 704.00
Part Throttle Tracking Idle TPS 0.04
Part Throttle Tracking Idle RPM 640.00
Part Throttle Tracking Idle A/F Ratio 14.80
Part Throttle Tracking Lean A/F Ratio 10.00
Part Throttle Tracking Gain 5.00
AFR Tracking: A/F 11.5
VE table: 2
AF User Tune Lo: -10%
What can I do?
Freq In Mode 11
Aux 1 mode 01
Main Scale 30.00
FE Smoothing 30
AFR Min TPS 3.00
AFR Min RPM 3200
AFR Min Load 150.89
TPS Enrichment 0.48
TPS Decay 0.80
TPS MAP Max 104.06
MAP Enrichment 0.40
MAP RPM Min 704.00
VE table: 2
