Reassembling my JDM 7M I have got #1 at TDC and I assume I have my cam pulley marks lined up with the notches as per the factory manual. Now maybe since my Distributor was already out this section may not apply. Page IG-17 describes how to remove the distributor. Why would you set at TDC then look through the oil fill hole and turn the crank until you see the cam nose and then turn it back to TDC and then remove the distributor?
Since I am sure I have the cam notches lined up with the cover notches and the crank pulley is at ZERO cant I just align the two grooves on the distributor and insert it into the head since everything is at TDC.
I just dont understand why they have you rotate and watch for the cam nose then rotate it back again.
