hydro fan thermistor
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
thermistor?? do you mean the temp sensor in the radiator????
if so the ones from the camry's will work.
can't remember what year camry, but i know one works.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
yes the temp sensor in the radiator. lower corner. ill will search and see if i can find what year camry that is. thanks
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
supramike7m;952105 said:
well from what i read the sensor off a mid 90's 1mz v6 camry will work. any one who can confirm this?
Yes, these camry's also came with hydro fan. Even the hydro fan ecu works from these camrys in 1JZ swaps. I have used them before.
By the way, if you just plug in the Hydrofan ecu , this will kick start the fan in higher speed at all times. I did not have any problems with it this way, The sensor does vary the speed once connected though.
