Hydro Fan Cooler
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Yes the factory one is a "U" shapped one about 2-3 feet wide with disc shapped heat sinks on the tube, I know because I used mine for the P.S. cooler its more efficient. If you have an auto radiator and manual transmission you can also use the bottom cooler on the radiator. Yes you could use the one on summit you want the line to be a 3/8 call to make sure.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Intrnlstorm;1570437 said:
Quick question for those that have been dealing with the hydro fan for a while. My hydro fan cooler is shot due to a front end accident. What can I use for a replacement? I read somewhere that a 7m turbo power steering cooler would work. Could I use something smaller?
Something like this? http://www.summitracing.com/parts/DER-13200/?rtype=10
I don't want my fan to burn up if the cooler is too small.
Joel
I'm using that one for PS and a custom made one for the HFC. I have an ss tube bender and I used ss compression fittings.
Supra-Man18
357
miami
Ive been running mine down here in miami for about 3 yrs.. I love my hydro fan but its so cluttered in the engine bay n now im supposed to cram a cooler elsewhere : / guess im going electric or clutch fan :/
