How to adjust e-brake for an 88
Supra5MGTE
421
Tampa, FL
or you need to tighten the slack in the lever cable. my '84's cable stretched out after 20yrs so i took the console apart and adjusted it. done.
HyRisk
Drifting since ∞
Sep 26, 2005
32
Yay Area
Well I looked at them and they're pretty much worn down. Id say almost completely gone. Time to give elmhurst a call.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I think the only uniform adjustment for the cable is where it mounts to the e-brake handle.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Have you actually measured them? They are not thick to begin with. The minimum thickness for the shoe lining is 1mm (.039"). The standard new thickness is only 2.5mm (.098") so double check that unless you already have.
