How much boost PSI are you running?
dmadma60
26
Central Texas
Datsrboi;1053459 said:
Just seeing what PSI you guys are running at :)
I am at stock 1JZ PSI (What ever that is.. I'm gaugeless)
Also do you guys feel a need to ever go pass 20psi?
10psi or so....11+ on colder days. Not sure why my 1JZ doesn't hit the 13-14psi others report with similar setups (intake, FMIC, 3" exhaust). My downpipe is stock but it can't be that huge of a restriction. I pressure checked my intercooler and pipes recently too....
nguyen95465
Yeadon, PA
I run ~18 psi
650 cc injectors
TO4R Turbo
clutch slips though so i might take it down to 14 till i feel like putting in my new clutch and flywheel.
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
21.5psi till i figure out what the hell is wrong with my wastegate/boost controller, then it'll be back to 1bar.
2j w/ gt40r
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
annoyingrob;1053763 said:
Why go back? You're in the meat of the efficiency range there.
maybe a prob with overboosting, spring set for 1 bar or something hehe
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
SPD TRP;1054112 said:
When does that gt40 reach full boost?
Wayne
its gonna depend on what exhaust A/R you have, plus your own motor setup
friends car with a .68 A/R 40-88 with crower 272 small cores hits a lil after 4K to do 1bar
