Okay, thanks. That might explain why I needed to add coolant recently...tissimo;944890 said:no thats the hose to the heater core. Its engine coolant, you need to fix it.
swaq;945169 said:It appears to be leaking as if it wasn't clamped down well enough. The hose isn't visibly cracked. It doesn't look like there is anything wrong with the clamp either though... I'm wondering if the shop bumped it while replacing the starter.
