Just curious if anyone has any ideas on a a replacement hood blanket or someway to fix it. Its comings apart around the edges and looks horrible. I dont really want to just remove it either.
Is it just separating the black part from the insulation underneath? If so some spray adhesive works great around the edges to keep it together. Water is the true enemy for that piece.
If repair isn't economical, I recall one of the sound deadening brands had an under hood sheet, both to keep noise down and repel heat. Not sure which brand it was though...
DEI is the only thing I've seen people use which is a silver shiny or gold adhesive to reflect the heat. I'm partial to the OEM, but they are discontinued.
