Mods list
-modify stock afm housing ( drill out plug so u can adjust the screw)
-basic narrow band, wideband if you got the cash more accurate, (to make sure you dont go lean)
-basic boost conttoller or elec if you got the cash
0-2000 ohm variable resistor(linear with a knobb to adjust resistance) or "pot" potentiometer
Splice the "pot" into the coolant temp sensor wire at the ecu (find a ecu pinout for your year very easy)
As you turn the knobb (adjust only when engine is warm ) resistance will increase telling the ecu the coolant is colder.this will raise injector pulse width. Giving a richer mixure.
I have just set this up in my 87at t and havent done much tuning with it yet. Before adding the "pot" it would take 4-5 psi to get in to the rich area of my a/f gauge at a 10 psi max, I wanted a little more safety so if I want as soon as I start to accelerate I can get a rich mixture or when crusing never get a rich mixure with the turn of a knobb . I call this a piggybabyback for under 10 bucks
