HKS F-CON Harness
Ok well last week while in pick and pull I came across an F-CON hanging out of an 88 Turbo Supra's glove box by it's harness so I pulled it out and also found it still has it's FCD and Pressure Sensor connected to it. I also found an old Boost controller mounted to its passenger side fender well. But anyway my Supra is an 89 and I want to install it but I can't find anything on a Harness for my year. I googled it and it says it's universal but aren't the ECU plugs different after 89? For safe measure I took the ECU too lol. Is there a plug n play harness for the 89 and up Supra's or do I have to hack it up and make it work?
drjonez
the motor city
www.4cefed.com
no chance that '88 harness will work on your '89- the plugs are different. yup, HK$ used to make a PnP harness for you....good luck finding one. if you're dead set on using the FCON, you might as well just hard wire it.
935motorsports
San Diego, CA
As long as your harness is in good condition.
Do you have a picture?
You can send it to
935 motorsports
2766 via orange way suite g
spring valley ca 91978
The one that I have is very new.
Its has the wiring for the pressure sensor and the FCD. It looks like it came pre-wired from HKS like that. I will get a pic up asap.
