So heres a little history of what happened. I replaced my w/pump back in Sept. with an aftermarket because it started to leak fromt the weeping hole. I drove the car for about a month and a half then parked it for the winter. I took it back out in late March, and drove it. Everythng was fine untill early July the aftermarket w/pump bearing let go and started to leak. So I replaced it with another after market pump that lasted not even 2 days. I got home and the pump was flowing coolant out of the car like Niagara Falls. It turns out this pump had its whole entire center section (Impeller, shaft, and pully) slip and grind 5/32nds into the rear timing cover housing. When i got around to replacing the pump again I bleed the car for about 1 1/2 hrs but I did notice a very bad sign. As I reved up the engine, I had a gyser of coolant come out of the rad. But after bleeding I drove the car no problems with overheating accoriding to the stock gauge it doesnt even attemept to pass middle or fluctuate. Plently of heat in the car no lose of power. I dont have to top up the bottle, and it doesnt overflow.
So im not going to denie the possiblity of a BHG, infact I think it is the case. I just want to clarify what you guys mean when the coolant in the resivior bottle "boils". Is it that you hear a girgleing sound at the front with the hood open or is actually boiling.
Because I checked the bottle before I leave when its cold and is a bout a 1/2 an inch about the low level. And after its hot its about 1 inch over the full level but im hearing this girgling sound formt the bottle and when I pull out the hose it goes away.
And yes i know that for shure way to tell if it is a BHG is a Exhaust Gas Tester for the rad. That will check for EG in the coolant system and a Compression test will test between cylinders
