High compression! Damnit to hell!
gaboonviper85
3,236
Northeast Philly
So this past weekend I purchased a comp guage and did a quick test on my supra (with hot engine)...
Only tested 1 and 6 as I was just playing around that day...anyway....both 1 and 6 are at 170 psi!!!!
Checked by pulling efi fuse, wot, cranked till needle stopped climbing....
Head measured .001" undersize after decking according to Toyota deck height spec....using a 1.3mm cometic as i wanted to keep stock compression...the headgasket cylinder bore is one size larger that stock so I figured I'd be just under stock comp but I'm way over!
Thoughts?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Spec is around 140psi but if you do some looking around i have read a lot of peoples compression reasings are higher that than. usually in the 150-165 range. You might have some carbon buildup, how new is the motor? I have a brand new rebuilt .040 with block and head machined with a 1.73mm Cometic hg and my compression readings were about 164, so i dont think your readings are much to be alarmed by.
http://www.supramania.com/forums/showthread.php?111222-compression-test-results-question&highlight=
http://www.supramania.com/forums/showthread.php?t=97725
92nsx
2,957
Clearwater, MN
Mine is is at 125-126 across the board , 500 miles when checked. She just isn't sporting to much Toyota stuff on the inside :p
Asterix
Lurker of Power
32
28
Vienna, VA
The last time I checked mine, #3 was 225 and the rest were 230psi, cold, about 25k after a rebuild. Sure, my timing is slightly off because the head is 0.030" too short, but it's close enough for me.
Asterix
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Asterix
Those numbers are very excessive!
