Hg thickness how thick
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Well, you've got .762mm shaved, so stock (1.2mm) + shaved (0.762mm) means 2.0mm would give you (about) stock compression. I'd opine that 1.8-2.0 would be in the acceptable range.
BryanDyer
654
Georgia
Zrain25;1948640 said:
Should I go stock compression or bump it up a little
lol whoever had the car before me chaved enough off and put a 3mm hg on I raise my compression to about 180 and as far as I know interanals are all stock
Zrain25
639
Pelham,New Hampshire
Bump this back up agian I'm gunna be going with the 1.9mm cometic. The block has been bored .20 over to my probe pistons. So I'm guessing I should run the 86mm bore size hg
or should I run the 84mm stock bore size?
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Stock bore is 83mm. .020 over is 83.5mm. .040 over is 84mm. An 84mm bore hg is good for up to .040 over. You still want as much material as you can have between the cylinders, as there's not a lot of extra to begin with. The 84mm bore leaves a bit of extra, but not too much.
