Helpp!! 1jz crank no start issue
surffer227
30
I just finished my 1jz swap in my 240, it ran fine for a day or two but now it will only crank and not fire, intermittently it will start and run for about a minute then cut off and just crank again. I have fuel pressure and I have tried a new ignitor but that didn't work. Any ideas??
theGOODWIN2012
Supraman
Oct 28, 2012
98
Long Island, NY
Double check on your coolant temp sensor. Though it was running fine for a few days before, if it happened to come loose that will cause no start. Not that that ever happened to me :biglaugh:
surffer227
30
Auto harness and auto soarer ecu I'm running a w58, I know the OBD plug is there just gotta see if it's wired in, at work now so I can't -_- would the temp sensor let it start once in a while?
Could be crank sensor.
Non vvti 1jz is obd 1 meaning the obd plug is useless. W pin on the ecu needs to go to the check engine light wire and then jump te1 and e1 in diag box on the intake manifold.
