Hello I need some help on getting some tunes back in my car. I want to keep the Stock HU. The radio has power. The original underseat amp UM-173 was corroded and I got no sound out of the speakers. I got a used amp. Mistakenly it looked the same but the number was different, um-201, and the color codes on the harness are different.
Everything plugs in just fine and I can hear the radio now but I have to turn up the volume all the way up to just hear it at a very low volume. The fade, Balance, Dim, Antenna all work. The only issue is the volume.
I have used this helpful link from ishii http://www.supraforums.com/forum/showthread.php?t=391532 but I am confused about the color assigned to the wires vs the pin positions. My Harness is factory and never been hacked.
Photos with descriptions are provided.
Here is my setup.
Here is my setup.
- 1989 supra with cd / radio / tape / externally amped 14 pin plug at back of radio and 8 speaker setup
- A voltmter and basic knowledge of schematics.
- A replacement amp with wire colors that do not match the old amp
