Help with misfire. Starts fine. Misfires while idling.
eighty-7t
chrono on SF
Apr 23, 2005
30
San Jose, CA
Hey guys. I have an 87 Turbo 5Spd. When i go to start it in the morning, it starts up fine. once the car comes down to about 600-700 rpm, the car starts to misfire. i recently replaced the plugs and went .031 with autolites. i took the car for a test drive and it runs fine until i boost. the car jerks a bit and feels like it wants to get up and go, but it doesn't. i also hit boost cut in 3rd gear. what's up with that? i had taken the cps out because at first the car was a no spark problem. turns out, it was coil number 3 that had a crack on the under side of it. i replaced it with another one, but the thing is, one of the holes where the wire goes into, is black and the other is the normal gold color. i'm getting codes 32 and 34.
ngk coppers pn 4644, or ngk platinum, or ngk iridiums. Use the coppers for high hp/boost levels.
Also did you set the ign timing when you put the cps in?
And the codes are either for afm or its wiring.
eighty-7t
chrono on SF
Apr 23, 2005
30
San Jose, CA
Thanks for the part number. I lined everything according to tsrm. I haven't timed it cause I don't have a timing light. Could it be that the cps is off one tooth?
AJ'S 88NA
2,419
Florida
Yes could be of a tooth by what you are saying, but you still need to time it with a light.
