help with fcon
88supraTT
292
around the bend
if anyone could tell me what chip E204 is and what it does that would be great..and if it dosn't work on a 89+ supra could i just get a different chip if i ordered one and just put it in?i can post pics if they are needed.i have a gcc also if that makes a difference.
thanks caleb
89TBen
97
Mizzou
well i checked on the hks website but i didn't find that chip it may be a jdm one. but there are chips designed for our cars. the numbers are E155, for use with stock injectors, E164, for use with 550cc injectors, and E105V for use with the VPC. all this info and more can be found a HKS's website -- http://www.hksusa.com/. and there is a few sites that sell the chips and other accesories. you can find them on ebay some times or at this site http://www.nolimitmotorsport.com/.
Ben
88supraTT
292
around the bend
srry i forgot to add it is a jdm one but i was kinda curious on what it dose.i did look at those websites and i emaild hks but i don't know when they are gonna get back to me so i thought i would ask.also if it is a jdm pfc would a usdm chip work in it?
thanks caleb
Bondango
Supra Specialists Ireland
E705 - 1JZGTE, 2JZGTE, 7MGTE, STOCK INJECTORS
E702 - 7MGTE, T04E TURBO, STOCK INJECTORS
E705V - 7MGTE, STOCK INJECTORS VPC
E111 - 5MGE, STOCK INJECTORS (remarks in japanese)
E118 - 5MGE, STOCK INJECTORS (remarks: SY I)
E102 - 5MGE, MTEU, 1GGTE, 1GGE, STOCK INJECTORS (remarks: SY I . II)
E114 - 5MGE, MTEU, UPGRADED INJECTORS (not sure of size.. in japanese)
E119 - 5MGE, STOCK INJECTORS (remarks: SY I . II)
E120 - 5MGE, UPGRADED INJECTORS (remarks: SY II . III)(not sure of size.. in japanese)
E182 - 1GGTE, T04E TURBO, STOCK INJECTORS (89-92)
E102V - 1GGTE, STOCK INJECTORS, VPC
E105 - 1GGTE, STOCK INJECTORS, 86-88
E115 - 1GGE, UPGRADED INJECTORS,
E129 - 1GGE, UPGRADED INJECTORS,
89TBen
97
Mizzou
yea i'm pretty sureyou can use any chip. i just think they had different chips for jdm. i think the unitis actally the same, no mater if its jdm or not. where did you get it? what injectors are you running? do you have the VPC?
and here is a quote right from the hks usa website on what the pfc f-con does-
"The HKS PFC F-CON is a plug-in fuel management system designed to supplement and refine the OEM fuel curve to maintain a proper air/fuel mixture when increasing boost pressure in turbocharged applications. The PFC F-CON optimizes the factory injector pulse width signal by recalibrating information obtained by both the PFC F-CON absolute pressure sensor and the OEM engine control unit (ECU). Each unit is application specific and includes a preprogrammed ROM for a particular performance stage."
88supraTT
292
around the bend
i know what it dose,i had been deciding between fcon and maft pro for a while and this poped up so i got it.no i don't have vpc i have been looking for one but right now i have the fcd and gcc i don't plan on creating a hole lot of power i have ct 26 60-1 right now and 550s,the 60-1 and 550s are not on the car right now.all i really wanted to know was what this chip "dose" if it is 440s chip 550s or 440s w/vpc or 550s w/vpc.becouse i am not sure. the guy said it was for a 89+ supra but has this chip in it i couldn't let it pass me up for 150.00.i figured i could figure out what this chip dose or i could just buy and nother one.
thanks for the input
caleb
89TBen
97
Mizzou
throw the fcd in the garbage. lol from what ive read on it they re a bad thing to have. do a search on i and read up. there's alot of info on the fcd.
88supraTT
292
around the bend
i don't really want to throw it away,their easy to use and ive read many good things about them,i don't plan on making a lot of power if i did i would probably buy a stand alone or somthing "better".this is somthing to just get me by untill i build the engine and go standalone.
thanks for the advice
thanks
caleb
89TBen
97
Mizzou
thanks
caleb
lol. i was just kidding about throwing it away. but you probably shouldn't use it on your car. i'm not tellin you what to do with your car but.... the fcd gets rid of the fuel cut on our cars. the fuel cut is there for the safety of our engines. what it does is cut the fuel off when you boosting to high. if you have a fcd that eliminates that and then bad things can happen. there are ways of RAISING your fuel cut, so that you still have that safety net. you would probably be better off sellin the fcd on ebay or something. but like i said i'm not tellin you what to do. just look up the info on the fcd or fuel cut ad use your own judgement. just tryin to help youout.
ben
88supraTT
292
around the bend
the fcd came with it and so did the gcc.so i got a pretty nice deal except for not knowing what the chip dose. i have a electronic boost controler but i have it set on .5 bar so i don't have to worry so much about over boost. but i am attending a tech school so i don't plan on putting the turbo and installing everything for a while yet becouse i may get a chance to rebuild the motor with free maching and about 1/2 off on all the parts i use including forged internals(i forget what brand they carry).i am really only useing the fcon as a means to add fuel i will be picking up a lm-1 shortly.
thanks for advice
caleb
