Help removing turbo knuckle
lxsirprize
33
WV
Hey all, any tips getting the turbo knuckle off? I have the entire exhaust removed all the way to the darn knuckle, but after removing the 4 nuts holding in onto the turbo, I cannot get it to budge off. I have a new exhaust kit all ready to put in place!
Any tips would be great!
I assume you mean the elbow. It's usually held on by rust seizing the studs in their holes, do some "percusive maintenance" is required.
i.e. break out a hammer and beat on it to break up the rust.
lxsirprize
33
WV
Thanks Poodles! Your right, I meant the elbow :p
Will do the hammer thing, just wasn't sure if there was more to it LOL
I'll have to post some pics of the old vs new as this was quite an experience working around the elbow!
te72
Classifieds Moderator
6,602
WHYoming
Redneck engineering 101, rule #1:
"If it should move and doesn't, use WD40. If it moves and shouldn't, use duct tape."
However, I usually recommend PB Blaster. That shit just WORKS in cases like this. I don't think I sheared even one bolt on the Chevy that I had given a couple coatings of PB. Was a little lazy with some things and sheared those bolts, but PB is a lifesaver.
lxsirprize
33
WV
Thanks all. Do you know if autozone carries PB blaster? If so, I'm going to go get some in the morning and spray the h#ll out of it!
Canuckrz
852
Calgary, Alberta
I use the toyota penetrating fluid personally, most of the other crap I've tried from auto parts store just doesn't do the same job. I can't remember the exact part number unfortunately, but they will obviously know what you're looking for.
lxsirprize
33
WV
Yea, day 2 and this thing isn't budging!!!
Another silly question, but the elbow just "slides on" and is held by these four bolts; right? :p
They're studs. The gap between the stud and the holes in the elbow get loaded with 20 years of rust.
PB blaster didn't do crap in this case, I just had to beat the snot out of it with a 5lb sledge...
IndigoMKII
2,181
Madison, Virginia
Mine was almost seized to the studs, not the surface. It was a PITA even after I got the surfaces to split apart. I used a dead blow hammer and a vise along with WD40.
lxsirprize
33
WV
Wow....I'm about to this point. 5lbs hammer and a bottle of PB blaster = need more patience LOL
Still swinging away so far....
Thanks P00, never owned a CT so haven't had this battle!
lxsirprize
33
WV
Damn...I swear this thing has turned into one single piece! Im about to take it to a shop and just pay someone else to take it off!
Will it damage anything if I drive without the exhaust and charcoal canister attached? Closest muffler shop is 8 miles away.
Just pound on it and use penetrating oil. It will come off. That's all a shop is going to do.
Driving without the exhaust right there could start a fire.
lxsirprize
33
WV
oh! I thought of that briefly.... okay. I guess the hammer and I have a date again tomorrow!
Thanks all for your input on this...this really is tougher than I thought!:cry:
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Lots of penetrating oil.
If you don't want to pound on it any harder, go buy a 5" bench vise and a triangular file. Put the point of the triangular file so that it's a wedge between the turbo hotside and the elbow. Put it in the bench vise, and use a snipe to crank on the vise handle.
lxsirprize
33
WV
Dan, good idea. I will definitely try this tomorrow. Beating that damn elbow is just killing me....the biggest tease is my 3" exhaust system in the garage reflecting its new goodness and mocking me! LOL
