Help Regarding Stinger (High Idle)
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
Well guys I got the 1JZ started today using the base map that Aaron gave me for the stinger. The only problem I am having so far is that my car idles at 2500 rpm. Any idea what is causing this?
turbo joe
91
Corona, CA
www.turbojoe.com
The stock IAC is probably part-way open.
The Stinger won't run that type of IAC directly, so unless you want to convert it to a 2-wire type, you'll need to block it off and set the idle with the idle stop screw.
BJ91T
810
Baton Rouge LA
we simply left it unplugged on the 1jz/stinger car here at the shop and it idles at 800 all day,(with the screw adjusted mind you).
BJ
Van Diesel
Powered by vino
Dec 12, 2006
396
El Paso, Texas
Yep, stock 1J ISCV is a normally open switch. Just get creative with it. Go to a powder coating shop and ask if they have any covers in that size.
10secdream
Got Boost?
Sep 11, 2007
767
Well I tried unplugging the ISCV and it still idles high. Is there any way to close it? Can I apply voltage the one of the ISCV plugs and get the valve to close? My other option is to make the block off plate but would prefer to try and close it first.
